Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Schema on the DB2 Host > Rerunning the InstallationIf you need to rerun the Siebel Schema installation from the beginning, either after completing an installation run or after starting but not finishing the run, enter a new log output directory name. You have to rerun the installation when you generate new DDL for the Siebel Schema based on a new or modified storage control file. |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
