Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > Dynamic SQL in the Siebel Application >
About Tracing SQL Generated by the Siebel Application
The SQL that the Siebel application generates is sent to the DB2 host on the z/OS platform through ODBC and the DB2 Call Level Interface (CLI) before the SQL command is processed by DB2. To effectively troubleshoot issues, you may have to trace the relevant SQL statement through one or all of these layers. Contact Siebel support personnel for guidance on the most appropriate tracing for the situation. Steps to initiate tracing are described in the following topics:
