Use the Siebel Database Storage Configurator (dbconf.xls).
This is a Microsoft Excel macro tool that allows you to import and edit attributes from one of the Siebel-provided storage control file templates. After you customize the template and save the resulting storage control file with a new name, the storage control file contains the actual names for the DB2 objects.
TIP: Append the name of your new storage control file with a suffix; for example, if you use storage_p.ctl for your input, name the resulting file storage_p_suffix.ctl, where you replace suffix with an identifiable character string.
The dbconf.xls file is installed in the DBSRVR_ROOT\db2390 (Windows) or $DBSRVR_ROOT/db2390 (UNIX) subdirectory. To open dbconf.xls, you must have Microsoft Excel installed on your workstation. For further information, see Modifying Storage Control Files Using the Database Storage Configurator.
NOTE: If your installation is UNIX, you must transfer dbconf.xls and the storage control file that you want to configure to your Microsoft Windows environment. Use BINARY FTP to transfer the dbconf.xls file.
