Siebel Marketing Installation and Administration Guide > Designing Marketing Campaign Load Formats > About Marketing Integration Objects > About the Marketing Person Integration ObjectMost deployments of the Siebel Marketing application use the Marketing Contact integration object for loading campaign data. The Marketing Contact integration object is most commonly used because it supports inserting new contact and account names into the transaction database. In contrast, the Marketing Person integration object only supports inserting new records into the Campaign History table for contacts or prospects that already exist in the transaction database. When all the customer data resides in the Siebel transaction database, the load process can avoid inserting new customers and improve the load time. The Marketing Person integration object supports this simple lookup load process. The Marketing Person integration object should be used only when all target contacts, accounts and prospects in the campaign already exist in the transaction database. The only required mapping is between the Row ID from the Contact and Prospect tables in the Siebel transactional database and the external data source, typically the Siebel Data Warehouse. For a list of fields for the Marketing Person integration object, read Field Names for Marketing Integration Components. Figure 4 shows the integration components for the Marketing Person integration object. Required fields apply when a new campaign contact record is inserted into the Siebel transactional database. Table 22 describes the integration component for the Marketing Person integration object. Mapping Rules for the Marketing Person Integration ComponentsWhen creating a campaign load mapping using the Marketing Person integration object, use the following guidelines:
| Siebel Marketing Installation and Administration Guide | Copyright © 2006, Oracle. All rights reserved. | |
