Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > RefineQuery MethodThis method refines a query after the query has been executed. SyntaxReturnsUsageUnlike ClearToQuery, RefineQuery retains the existing query specification and allows you to add search conditions based only on those fields that have not been set by previous search expressions. RefineQuery may be most useful when used in conjunction with GetNamedSearch. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following Siebel VB code fragment shows how RefineQuery might be used. me.ActivateField "Status" See Also |
| Siebel Object Interfaces Reference |
