Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events > BusComp_CopyRecord EventThe CopyRecord event is called after a row has been copied in the business component and that row has been made active. SyntaxReturnsUsageBusComp_CopyRecord is called instead of BusComp_NewRecord when a new record is created:
Used With |
Siebel Object Interfaces Reference |
