Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Data Services API Methods > InsertOrderItem MethodInserts an order line item that is defined in the input. If the order line item already exists, the method updates the existing order line item. Syntax
ArgumentsError ConditionsThis method calls the help method described in DeleteQuote Method. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
