Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Data Services API Methods > UpdateOrderItem MethodUpdates the existing order item that is matched by user key and updated with the value in the input. Syntax
ArgumentsError ConditionsThis method calls the help method described in DeleteQuote Method. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
