Siebel Order Management Guide > Product Data Service and Import/Export API Reference >
Summary of Data Service API Methods and Sample Workflows
A set of sample workflows, whose names begin with PDS, are examples of how to call the Product Data Service API methods and how to parameterize inputs. Though these workflows are shipped with the product, they are meant as examples of how to create your own workflows that use the Product Data Service API, and they are not meant to be used directly. The inputs and outputs of the Product Data Service API methods are all in the format of the Siebel property set, which can be converted to and from xml files using Siebel EAI. The hierarchy in the output property set is controlled by the Integration Object specified in the input Siebel message. Table 38 summarizes the Product Data Service APIs, the methods in each API, and the sample workflow that calls each method. One of the sample workflows is described in PDS PublishCatalog Test Sample Workflow. After reading this topic, examine the other sample workflows in the product to see how all of the methods are used.
Table 38. Data Service APIs, Methods, and Workflows
Catalog API |
Get Catalog |
PDS GetCatalogs |
Get Catalog Categories |
PDS GetCatalogCategories |
Get Category Products |
PDS Get CatagoryProducts Test |
Get Products |
PDS GetProducts Test |
Get Product Details |
PDS Get Product Detail Test |
Publish Catalog |
PDS PublishCatalog Test |
GetFavorites |
PDS Get Template Test |
GetFavoriteItems |
PDS Get Template Item Test |
Product Details API |
Get Product Attribute Domain |
PDS GetProductAttributeDomain |
Get Related Products |
PDS GetRelatedProducts |
Get Related Promotions |
PDS GetRelatedPromotions |
Get Product Children |
PDS GetProductChildren |
Search API |
Get Search Options |
PDS GetSearchOptions Test |
Get Search Parameters |
PDS GetSearchParameters Test |
Execute Search |
PDS ExecuteSearch Test PDS ExecuteSearch External Test |
Add Favorite API |
AddFavoriteToQuote |
PDS Add Favorite To Quote |
AddFavoriteToOrder |
PDS Add Favorite To Order |
AddFavoriteItemToQuote |
PDS Add Favorite Item To Quote |
AddFavoriteItemToOrder |
PDS Add Favorite Item To Order |
Quote / Order API |
Insert Order |
PDS Insert Order Test |
Insert Order Item |
PDS Insert Order Item Test |
Insert Quote |
PDS Insert Quote Test |
Insert Quote Item |
PDS Insert Quote Item Test |
Set Active Order |
PDS Set Active Order Test |
Set Active Quote |
PDS Set Active Quote Test |
Update Order |
PDS Update Order Test |
Update Order Item |
PDS Update Order Item Test |
Update Quote |
PDS Update Quote Test |
Update Quote Item |
PDS Update Quote Item Test |
Delete Order |
PDS Delete Order Test |
Delete Order Item |
PDS Delete Order Item Test |
Delete Quote |
PDS Delete Quote Test |
Delete Quote Item |
PDS Delete Quote Item Test |
Get Active Order |
PDS Get Active Order Test |
Get Active Quote |
PDS Get Active Quote Test |
