Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Versioned Object Data Import and Export Business Service Reference > ExportVOD MethodExports stand-alone objects from a Joint Workspace project or a single VOD Definition, based on supplied parameter values. Determines a set of objects to be exported based on input, and produces a list of EAI property sets, corresponding to all of them. The resulting list of PropSets is wrapped in a single parent property set and returned in the output argument. Syntax
Arguments
Details of Input Arguments: combination 1 If this combination of values is passed to the method, it considers each entry in the content of the JWS project as a Root object. The resulting combined property set will include all of them. Details of Input Arguments: combination 2
If this combination of values is passed to the method, it considers a single entry as a Root object. The resulting property set will include only this object (as a child property set). Error ConditionsMight return generic error codes from Object Manager, From EAI or from service. These codes are mainly about input format, for example, that a parameter is missing parameter. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
