Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Versioned Object Data Import and Export Business Service ReferenceThis business service allows you to move versioned object definitions between databases. It supports the following versioned object definitions:
It also allows you to fix S_PROD_INT records created with EIM processes, making them usable by the ISS framework by creating the minimum set of necessary records needed for versioned objects. For more information about importing and exporting versioned objects, see Product Administration Guide. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
