Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Versioned Object Data Import and Export Business Service Reference > Post_EIM_Upgrade MethodThis method locates all records in S_PROD_INT with missing or broken association with the S_VOD record and creates the necessary supporting structure for versioning. Depending on input property set parameters method can operate in 2 different modes: standard or staging mode For each identified entry in S_PROD_INT, it does the following:
In Staging mode, it continues by doing the following: In Standard behavior mode, it continues by doing the following:
In both modes, if you set the property ReportOnly = TRUE, the upgrade does not occur and the method only generates a report of orphan records. In this case, the output property set's property Warning contains a report of errors or list of orphans. SyntaxErrCode DoInvokeMethod (const SSchar* pMethodName, const CCFPropertySet& inputArgs, CCFPropertySet& outputArgs) ErrCode Post_EIM_Upgrade (const CCFPropertySet& inputArgs, CCFPropertySet& outputArgs); ArgumentsDetails of Input Arguments (standard mode) Details of Input Arguments (staging mode) |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
