Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Versioned Object Data Import and Export Business Service Reference > ImportVOD MethodDecomposes the content of the input argument property set into individual objects, locates appropriate VOD in the target database by using Object Num value as a key, locks the object, and overwrites Workspace version content with data supplied in the property set. Successfully imported object references are added to the content of JWS project specified in the input parameters. Conflict resolution is done in the following way:
All conflicts are reported in string format in the output property set's parameter Warning. Syntax
ErrCode ImportAlgorithm(const CCFPropertySet& inputArgs, CCFPropertySet& outputArgs); ArgumentsError ConditionsMight return generic error codes from Object Manager, From EAI or from service. These codes are mainly about input format, for example, that a parameter is missing parameter. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
