Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Workflow Reference > ISS Approval (Order) WorkflowISS Approval (Order) workflow, shown in Figure 24, validates approval rules and creates approval items if necessary. It is triggered when the user selects the Generate Approvals menu item on the Order Header applet menu. This menu item raises the ApproveItem Signal, which calls this workflow. Workflow Description. This workflow does the following:
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
