Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Workflow Reference >
Contact - New Order Workflow
Contact - New Order Workflow, shown in Figure 15, creates a new Order for the current Contact. It then navigates to the Order Entry screen, then the Detail Orders View. It is triggered from the Contacts screen, Contact List applet menu.
Figure 15. Contact - New Order Workflow
Workflow Description. This workflow does the following:
- Create New Order. Creates an order for a contact.
- Goto Order View. Invokes a Sub-process called Goto_Order, which navigates to Order Entry - Detail Orders View
