Siebel Order Management Guide > Creating a Quote or Sales Order > Common Tasks for Creating Quotes and Sales Orders > Working With Line Items of Quotes and OrdersAfter adding products to a quote or order as line items, users may need to work with the line items in the following ways:
This task is part of the Common Tasks for Creating Quotes and Sales Orders. Viewing the Price WaterfallThe end user can view a price waterfall, which displays all the steps that went into the calculation of the line item, beginning with the start price and listing all the discounts, markups and final price. The waterfall can be used to answer customers' questions about how prices were calculated.
Deleting a Line ItemSometimes an end user may need to delete a line item to remove a product from a quote or an order. NOTE: To delete a component of a product with components, the end user must do so in the configuration session. The end user cannot delete a component by deleting a record in the line items list, as described in the following procedure. Customizing a ProductEnd users can customize some products in a quote or order by selecting their components. For instance, if a customer is buying a computer, the customer can select components such as the type of monitor, hard drive, and so on. To create the quote or order, the end user first adds the computer system as a product line item, and then customizes it using Siebel Configurator. The end user can tell when a product can be configured because the Customize button is enabled when the product record is selected. When a customizable product has components, the end user can expand the item to see the components included in the customizable product. For more information about customizable products, see Siebel Product Administration Guide. NOTE: The customize feature is only available if you have licensed Siebel Configurator.
Changing Component QuantitiesA customer might want to order a different number of components than what is set as the default in a product with components. Typically, end users change the quantity of a component in the configuration session that starts when they click the Customize button in the Line Items list. When an end user clicks Customize, Siebel Configurator checks all configuration rules to make sure that the change in quantity is appropriate. Your company can decide to allow changes to component quantities directly in the Line Items list in the quote or order. For this to occur, a user property must be set in Siebel Tools. For more information, see Configuration with Siebel Tools. When this user property has been set, the Qty field in line item for components of products with components is editable. If the Qty field is read-only, then this user property has not been set. Selecting Product Attributes for Line ItemsSome products have attributes that the end user can choose. For example, a shirt may have the attribute of size, with the possible values S, M, L, and XL. If the product has both components and attributes, then the user selects both the attributes and components during the configuration session, as described in Customizing a Product. If the product is a simple product with attributes, meaning that it has attributes but does not have components, then the user can either:
To select attributes for a line item
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
