Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications >
Verifying the External ATP Check Business Service User Properties
You must verify the External ATP Check business service user properties. This task is a step in Process of Setting Up Third-Party Product Availability Applications. To verify the External ATP Check business service user properties
- In Siebel Tools, select the External ATP Check business service.
- Select Business Service User Prop.
- Verify that the Names and Values of the User Properties match those in the following table.
siebel_port_name |
Default |
siebel_web_service_name |
External ATP Check |
siebel_web_service_namespace |
http://siebel.com/asi/ |
