Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Configuring Web Services for Availability to PromiseWeb services are used to direct the inbound and outbound messages to and from:
You must make sure that the Web services are correctly configured. This task is a step in Process of Setting Up Third-Party Product Availability Applications.
For more information about configuring Web Services and setting up demonstration scripts, see Integration Platform Technologies: Siebel Enterprise Application Integration. Using the ATP ASI Testing ScriptThe ATP ASI test is a testing script that simulates a simple fulfillment engine. It writes the output and response to an XML file on the server machine. By default the script writes the output and the response to ${SIEBEL_HOME}/bin, for example, D:\Siebel\bin. It writes an output file called ATPOutput.xml. This file represents what you would be sending to your middleware or fulfillment engine. Then the script generates a real-time response and sends the XML back to the Web service. The XML response that is generated is written into a file called ATPFinished.xml, which you can see in the file system. This testing infrastructure allows you to analyze what will be sent to the middleware and what the Siebel Business Application is expecting back, and allows you to test your user interface. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
