Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Extending the ASI for Availability to PromiseIf you want to extend the ASI, you must add fields to: This will create the necessary mapping between the ATP interface structure and the Siebel Quote and Order business components. NOTE: If you make changes to these objects, the names of the fields in the Internal and External integration objects must match. If you add a field, make sure that the names of the fields in the Internal and External integration objects match. For example, if you want to add the field Account DUNS# that maps on quote to Account DUNS#-quote and on order to Account DUNS#-order, you would do so as shown in Table 9. If this is a field that you do not want the fulfillment engine to be able to modify, such as Ship To Address Id, add the NoUpdate Field user property to the internal response integration objects, as follows:
For information about how to extend the integration object, see Integration Platform Technologies: Siebel Enterprise Application Integration. This task is a step in Process of Setting Up Third-Party Product Availability Applications. To prevent an added field from being modified by the fulfillment engine
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
