Siebel Order Management Guide Addendum for Industry Applications > Workflows for Customer Asset-Based Ordering > Workflow to Ungroup Quotes > CUT eSales - Ungroup QuoteThis workflow decomposes all or some line items into multiple instances with a quantity of one where the quantity is greater than 1. This workflow is shown in Figure 30. The end user starts this workflow by clicking the Ungroup button in the Shopping Cart View. Ungrouping Selected Line ItemsIf any line items are selected when the end user clicks the Ungroup button, FrameEventMethodUgroupSelected is called to ungroup only those selected line items. This workflow decomposes the root item, associated with the selected item, and all its children into multiple instances, each with a quantity of one where the original quantity is greater than 1. Ungrouping All Line ItemsIf not line items are selected when the end user clicks the Ungroup button, FrameEventMethodUngroupAll is called to ungroup all the line items. NOTE: If this workflow variations used, you must change the configuration by removing the select item column from the shopping cart. The user starts this workflow by clicking the Ungroup button in the Shopping Cart View when a line item is selected. Figure 30 represents both variations of the workflow. Workflow Description. This workflow:
Associated Business Service Methods. The following table shows the steps in this workflow that call business service methods. |
| Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
