Siebel Order Management Infrastructure Guide > Product Selection and Pricing Engine >
About Tuning Performance of PSP
Consider the following when tuning the performance of your preconfigured and custom PSP procedures: Preconfigured PSP Procedures
Tune the preconfigured PSP procedures by:
- Removing steps that your implementation does not require
- Eliminating unused values from the variable maps
General Design Guidelines
Follow these general design guidelines to further improve the performance of PSP:
- Optimize eligibility PSP procedures by:
- Executing low-cost tests first
- Performing high-cost tests (such as Web Service calls) only in post-pick processing
- Build performance hints into the procedure definition. Use the Process Condition input argument in each step to identify the subset of rows in the row set that require processing (for example:
{Row.Promotion Id} IS NOT NULL). This can eliminate unnecessary SQL and in-memory operations.
- When multiple steps operate on the same subset of rows, split the row set, perform the operations on the subset of rows, and then merge the two split row sets afterwards.
- Avoid unnecessary subprocedures. Subprocedure calls involve copying the row set, which should be avoided where possible.
- Optimize external Web Service calls by:
- Designing the Web Service interface to be set-based
- Making sure that a single invocation will process all rows in the row set
- Use PSP Cache for caching of database query results. For more information on how to tune PSP performance with caching, see About PSP Cache.
SQL Queries
Use the following guidelines to improve the SQL query performance of PSP:
- Minimize the number of SQL queries executed. Consolidate multiple Simple Look-Up steps into one step if the steps use data from the same reference data business component with the same search specification.
- Tune SQL queries by:
- Querying through thin business components to minimize Siebel Object Manager overhead and reduce query complexity.
- Making sure that all search specifications have index coverage.
Logging of Performance
PSP provides logging of performance-related data. Analyze the PSP log to determine which steps are consuming the most processing time and where the caching can be further optimized. PSP logging that takes place in the server environment is more effective than PSP logging that takes place locally, because in the server environment there is only one environment variable controlling the log level for all the events. You can use the events listed in Table 32 to log the performance of PSP.
Table 32. Server Parameters for Logging Performance of PSP
Object Manager Business Service Operation and SetErrorMsg Log |
ObjMgrBusServiceLog |
Logs the performance of business service methods which include the PSP transform methods. |
Workflow Performance |
WfPerf |
Logs the performance at the workflow level or step level. |
PSP Cache Event For more information, see About PSP Cache. |
PSPCache |
Logs the performance of PSP Cache. |
When debugging the pricer, the price waterfall output provides valuable clues as to which transforms and actions were executed. For more details on logging, see About Logging of PSP.
