Siebel Partner Relationship Management Administration Guide > CHAMP Planning > Using Partner Plans >
Adding a Plan and Its Highlights
The first step to create a new plan is to add a new Plan record, with which you will associate the information about the plan. When you add a plan record, you should also enter the highlights for the plan, which are an overall view of the goal, value propositions, and critical success factors for the plan. To add a new plan and its highlights from the CHAMP Planning screen
- Navigate to the Site Map > CHAMP Planning screen > All Plans Across Partners view.
- In the Partner Plans list, click the menu button, and then click New Record to add a new record to the list.
- Enter the information in the following table in the fields of the new record and of the More Info form.
Name |
Enter a name for the partner plan. |
Partner |
From the list of partner companies, select the name of the partner for which this plan is being created. |
Period |
Select the period for which the plan is valid. For example, the picklist might contain 2005 or Q2 2006. |
Period Type |
This read-only field displays whether the period you selected is a quarter, month, year, and so on. |
Start Date |
This read-only field displays the start date of the period you selected. |
End Date |
This read-only field displays the end date of the period you selected. |
Status |
Select the status of the plan. When you are working on creating the plan, select In Progress. When you submit the plan for internal review, select Pending Review. Later, as the plan is approved by the internal audience, select Internally Approved and when the plan is approved both by the internal and the partner audience, select Jointly Approved. |
Publish to Partner |
This field indicates whether the plan is visible to the partner through the Siebel PRM Web site. When you are creating the plan, select False. Later, after the plan has been internally approved and is ready to be approved by the partner, select True. |
Active |
This read-only field indicates whether the plan is still active. It is automatically set to True on the start date and set to False after the end date. |
Created Date |
The date when the plan record was created is entered automatically. |
Created By (Created by Name) |
The Login ID of the person who created the plan is entered automatically. |
Last Updated (Updated Date) |
The date when the plan record was last modified is entered automatically. |
Last Updated By (Updated By Name) |
The Login ID of the person who last modified the plan is entered automatically. |
- Click the plan name to drill down to the Plan Objectives view of the CHAMP Planning screen, which is used for adding objectives to the plan.
- To add other key information about the plan, click the Plan Highlights view tab.
- In the Plan Highlights form, enter the information in the following table.
Goal |
Enter the plan's goal, describing the overall purpose of the plan. For example, a plan goal could be Increase market share for the new servers by 20% before the end of fiscal year 2005. |
Value Proposition to My Company |
Enter a description of the plan's value proposition to your company. For example, the value proposition could be Increased market share for my new servers. |
Value Proposition to Partner |
Enter a description of the plan's value proposition to this partner company. For example, the value proposition could be New line of business. |
Value Proposition to Market |
Enter a description of the plan's value to the market. For example, the value proposition could be Availability of better and high-performance server products. |
Critical Success Factors |
Enter a description of the critical success factors of the plan. For example, some of the critical success factors could be Timely training and certification of the partner in the new server products and Timely execution of focused marketing campaigns. |
Adding Objectives to the Plan
Objectives establish specific goals for the partner plan, which are used later to measure the partner's success in implementing the plan. When you create an objective, you enter a target for that objective. After the plan has been completed, the actual performance data can be entered manually or automatically. An objective is defined using metrics. Metrics allow objectives to be measurable and categorized. Objectives can be revenue or nonrevenue. For example, "Generate $3M in revenues" is a revenue objective while "Train three employees from the partner company" is a nonrevenue objective. To allow measurement of both these types of objectives, Siebel PRM allows you to define quantity and amount metrics as follows:
- Quantity. If the objective is a quantity, enter the target quantity when you create the objective and enter the actual quantity after the objective is completed. For example, if your company is trying to sell a new line of printers, the measure could be the number of printers the partner has sold.
- Amount. If the objective is an amount, enter the target amount when you create the objective and enter the actual amount after the objective is completed. For example, if your company is trying to achieve $3M in sales by selling a new line of printers, you could measure your partner on the amount of sales revenue generated by selling the new line of printers.
To enter plan objectives
- Navigate to the CHAMP Planning screen.
- From the Show drop-down list, choose All Plans Across Partners.
The Partner Plans list appears.
- In the Partner Plans list, select the plan to which you want to add objectives.
- Click the Plan Objectives view tab.
The Plan Objectives list appears.
- In the Plan Objectives list, click the menu button, and then click New Record to add a new record to the list.
- Enter information in the following table about the objective in the new record and in the More Info form.
Name |
Enter a name for the objective. |
Strategy |
Enter a general summary of your strategy for how this objective will be achieved. |
Metric |
Select the metric that will be used to measure the objective. |
Initiative |
Select the initiative to which this objective is linked. |
Internally Accountable |
Select this flag if your company is accountable for meeting this objective. (If both your company and the partner company are accountable, select both the Internally Accountable and the Partner Accountable flags.) |
Partner Accountable |
Select this flag if the partner company is accountable for meeting this objective. (If both your company and the partner company are accountable, select both the Internally Accountable and the Partner Accountable flags.) |
Target Quantity |
Enter the target value for the metric associated with this objective. |
Target Amount |
Condition Clause |
Enter a brief description of the condition that must be satisfied. |
Training Course |
Optionally, select the training course that must be completed as part of the objective. |
Product |
Optionally, select the product that the partner must sell, be trained on, or work with, as a part of the objective. |
Target Industry |
Optionally, select industries that are targeted as a part of the objective. |
Target Market |
Optionally, select the market that is targeted as a part of this objective. |
Fund |
Optionally, select the market development funds that will be used for the objective. |
Actual Quantity |
At the end of the plan period, enter the actual value for the metric. You can do this manually, or if the product has been configured with the appropriate workflows or business services, it can be done automatically. |
Actual Amount |
Condition Met |
When the plan has been completed, if the metric has a condition, select this flag if the condition clause was satisfied, or leave it unselected if the condition clause was not satisfied. |
Shared |
This flag defaults to True to indicate that this objective is shared with the partner and is a CHAMP objective. If you deselect this flag so the objective is not visible to the partner, then you should select the Internally Accountable flag and deselect the Partner Accountable flag, to indicate that your company is solely accountable for this objective. |
- Continue to add new records to the Objectives list until you have entered the objectives for this plan.
Associating Opportunities with Each Revenue Objective
If an objective is a revenue objective—that is, if it has a metric such as sales revenue or some other form of direct revenue—you can associate it with an opportunity or opportunities. This feature lets you develop a road map of how the revenue target will be achieved in terms of the available opportunities. You can associate one or more opportunities with each revenue objective. To associate an opportunity plan with a revenue objective
- From the Show drop-down list, choose Objectives.
- In the Plan Objectives list, select the objective with which you want to associate an opportunity.
- Click the Opportunity Plan view tab.
The Opportunity Plan list appears.
- In the Opportunity Plan list, click the menu button, and then click New Record.
The Add Opportunities dialog box appears.
- Choose one or more opportunities and click OK.
The Opportunity Plans are added to the Opportunity Plan list.
Adding an Action Plan and Resources for Each Objective
You should develop a specific action plan for every objective. An action plan is a list of activities that your company and the partner company will perform to achieve the objective. When you create the action plan, you give each of its activities a planned start date and completion date. As you execute the plan, you enter the actual start and completion dates for each activity. If an activity is created by a partner or assigned to a partner, your partner should record its progress by using the Siebel PRM Portal to enter the begin and completion dates, and you can check its progress using the Siebel PRM Manager. You should also specify the resources that you will have available for each activity in the action plan. To add an action plan and resources for an objective
- Click the Action Plan view tab.
The Action Plan list appears.
- In the Action Plan list, click the menu button, and then click New Record to add a new record to the list. Enter information from the following table about the first activity of the action plan in the new record's fields.
Name |
Enter a name for the activity. |
Description |
Enter a description of the activity. |
Type |
Enter the type of activity, such as customer visit. |
Assigned To |
The person who created this activity is automatically entered in this field. |
Status |
Choose a value to indicate the progress of the activity. |
Due |
Enter the date on which this activity is due. |
Priority |
Select a value that indicates the importance or urgency of this activity. |
Planned Start |
Enter the planned start date of the activity. |
Planned Completion |
Enter the planned completion date of the activity. |
Actual Start |
When a user begins working on this activity, the user enters the date in this field. |
Actual Completion |
When a user completes this activity, the user enters the date in this field. |
% Complete |
When users work on the plan, they can indicate how close this activity is to being completed. |
Account |
Select the account that is related to this activity. |
Programs/ Other Comments |
Optionally, enter materials, equipment, any program participation information, or other miscellaneous comments. |
Last Name |
Optionally, enter the last name of the contact related to this activity. |
First Name |
Optionally, enter the first name of the contact related to this activity. |
Associated Cost |
Optionally, enter the amount of money needed for this activity. |
Campaign |
Optionally, select a campaign that is associated with this activity. |
Fund Request |
Optionally, select a fund request associated with this activity. |
Site |
The location of the selected account. |
- In the Resources list, enter the resources from the following table that you will have available for this activity in the Resources form.
Last Name |
Enter the last name of the person who works on this activity. |
First Name |
Enter the first name of the person who works on this activity. |
Job Title |
Enter the job title of the person who works on this activity. |
External Organization |
Enter the organization of the person who works on this activity, if it is not in your own organization. |
Email |
Enter the email address of the person who works on this activity. |
Work Phone # |
Enter the work phone number of the person who works on this activity. |
Home Phone # |
Enter the home phone number of the person who works on this activity. |
Alias |
Optionally, enter an alias for the person who works on this activity. |
