Siebel Partner Relationship Management Administration Guide > CHAMP Planning > Using Partner Plans >
Adding Notes to the Plan
You can add notes when you are creating a plan or when working on the plan after it has been approved. Notes let you enter free text comments about the plan. There are two types of notes:
- Private Notes. These are notes that can be seen only by the person who created the note. These notes are used to record miscellaneous information about the plan for your own use.
- Shared Notes. These are notes that can be seen by everyone in your company who has access to that view and record. These notes are used to share miscellaneous information about the plan.
To add notes to a plan
- Navigate to the CHAMP Planning screen > All Plans Across Partners view.
- In the Partner Plans list, select the plan to which you want to add a note.
- Click the Plan Notes view tab.
- Add a new record to either the Shared Notes or the Private Notes list.
- From the following table, enter the note in the new record's fields.
Created |
The date when the note was created is entered automatically. |
Note Type |
Enter the type of the note. For example, it might be "Directions" or "Reference." |
Note |
Enter the text of the note. |
