Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Partner Relationship Management Administration Guide > CHAMP Planning > Executing the Plan and Evaluating PerformanceAfter the plan has been jointly approved, your company and the partner company can execute the plan. You should analyze and evaluate the performance of your partner companies while the plan is being executed and after the plan is completed. |
Siebel Partner Relationship Management Administration Guide |
