Siebel Partner Relationship Management Administration Guide > CHAMP Planning > Creating CHAMP Metrics >
Adding New CHAMP Metrics
Before you add new metrics, analyze your CHAMP planning program and decide what metrics you will need to measure the performance of your CHAMP participating partners. To add a new CHAMP metric
- Navigate to the Administration - Application screen > List of Values.
- In the List of Values list, click the menu button, and then click New Record.
The Find List of Values form appears.
- In the Type field, enter CHAMP_METRIC_CD.
- In the Order field, enter the order in which this metric will appear on the list of values in the picklist for the Metric field of Objective records.
- In the Display Value field, enter the name for this metric that will appear in the drop-down list for the Metric field of Objective records.
- Click Language Name, and select the language for this record.
- Other fields are optional and are not generally used in CHAMP planning. Complete the other fields only if you have a special reason to do so.
This metric is added to the Metrics drop-down list.
