Siebel Partner Relationship Management Administration Guide > CHAMP Planning > Creating InitiativesAfter you have created the appropriate CHAMP metrics, you can begin the CHAMP planning. The first step in CHAMP planning is to create initiatives to outline your high-level partnership strategies. A partnership initiative is a large-scale or general business strategy that involves working with partners. For example, if a computer manufacturer wants to work with its partners to penetrate the untapped market segment of financial services, it might create an initiative named Foray into Financial Services. It might use existing partners, such as value-added resellers, to work on this initiative or form new partnerships with partner companies that have experience in this industry. As part of creating an initiative, you should specify which partners will participate in it. To create an initiative, you go through the following process: |
| Siebel Partner Relationship Management Administration Guide |
