Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > Applying to Partner Programs >
About Applying to Partner Programs
Partners who are not registered for partner programs can apply to partner programs on the PRM Portal as well as those who have already registered (registered meaning the partners have some visibility to the program). The following procedure allows partners to apply to a partner program. To apply as a partner (partner)
- Log in to the PRM Portal and navigate to Site Map > Partner Programs screen.
- Select and drill down on the program you want.
- Check for literature attachments, check for any existing applications, and check the membership data.
NOTE: Make sure you are not currently a member of this partner program. If you are already a member, you will not be allowed to apply again.
- Click Apply, complete the fields in the application, and then click Submit.
- To check the status of your application, click the Program Applications tab and query for the application.
NOTE: SmartScript enables you to click Save if you need to stop before the application is completed, and then click Resume when you return to it without losing the data you have already entered.
