Siebel Partner Relationship Management Administration Guide > Partner Programs Administration >
Applying to Partner Programs
After the partner program has been set up, and the partner user application has been created, the partner can launch the PRM Portal to apply for membership to the program. Only partner programs with the status Active are visible to partners on the PRM Portal. If the catalog/category is marked as Private, the partner must be added into the access group. If the program is not checked as Available to All, the partner has to be added to the Eligible Partners list to be able to see the program on the PRM portal.
