Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > Setting Up Partner Programs >
Setting Up Catalog Translations
Setting up catalog translations provides the ability to translate fields from the partner program so that partners can view them in their language. This task is a step in Setting Up Partner Programs. Use the following procedure to set up catalog translations. To set up catalog translations (brand owner)
- Navigate to the Partner Program screen > Program Detail view and select the program for which you need translation.
- Click the Translations tab and then click New.
- In the Language Code field, select the language you want.
- Complete the Program, Description and Long Description fields.
