Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > Setting Up Partner Programs >
Adding Literature to a Partner Program
Adding literature allows partners to download collateral, terms and conditions and so on that detail the partner program. The partner can access this literature by drilling down on the partner program in the catalog on the PRM Portal. This task is a step in Setting Up Partner Programs. To add literature to a partner program (brand owner)
- Navigate to Partner Programs screen > Program Design and create a program, or select an existing partner program to which you want to add literature.
- Click the Literature tab and query for the literature you want to add, or click Add and select the literature.
