 Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > Setting Up Partner Programs >
Setting Up Related Programs
Related programs are programs that have a relationships with a base program. There are two types of related programs:
This task is a step in Setting Up Partner Programs. To set up an addenda program
- Navigate to Site Map > Partner Programs screen > Program Design view, and create a new program.
 - In the Partner's Program applet, select the base program to which you want to relate the addenda program.
 - Click on the Related Programs tab and in the Name field, and query for and select the Addenda program you created.
