Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > About Eligibility Administration > Creating an Eligibility List ManuallyTo create an eligibility list manually, you enter information about each partner program to generate a picklist. Note that this method might not be practical for a long list of partner programs. If you have a lot of partner programs, see Creating an Eligibility List Using Analytics Data Load. Use the following procedure to create an eligibility list manually. To create an eligibility list manually (brand owner)
| Siebel Partner Relationship Management Administration Guide |
