Siebel Partner Relationship Management Administration Guide > Managing Sales > Scenarios for Forecasting Partner Sales >
Partner Managers at the Brand Owner Forecast Revenue for Multiple Partners
In this scenario, a channel manager forecasts revenue for multiple partner companies. The brand owner forecasts revenue for all partners that a partner manager oversees. The Brand Owner Forecasts Revenue for All Partners that a Partner Manager Oversees
In this scenario, there are multiple channel managers at the brand owner organization. Each channel manager oversees partnerships with a distinct group of partner organizations. A channel manager at a brand owner organization wants to track the revenues associated with his or her own partners, but does not want other channel managers to be able to view these forecasts. In this scenario, only the channel manager can see the forecast. This scenario consists of the following steps:
- Step 1. Create the forecast series
- Step 2. Create the forecast
Step 1: Creating the forecast series
The channel manager creates a forecast series that defines forecasts that would cover the annual revenue of three specific partners (Partner X, Partner Y, and Partner Z) and be run once every quarter. To create the forecast series
- Navigate to the Site Map > Administration - Forecast screen.
- In the Forecast Series list, click the menu button, and then click New Record.
- Enter the values in the following table in the fields of the new record.
Name |
A name for the forecast, such as Channel Manager's Annual Forecast of Partners X, Y, and Z. |
Auto Forecast Search Spec |
([Sales Rep Organization] = 'Partner X' or [Sales Rep Organization] = 'Partner Y' or [Sales Rep Organization] = 'Partner Z') and [Committed] = 'Y' and [Calculated Primary Flag] = 'Y' |
Description |
A description of the forecast, such as Channel Manager's Annual Forecast of Partners X, Y, and Z - Committed. |
Active |
checked |
Detail Depth |
Summary Only |
View Mode |
All Across Organizations |
Interval Period Type |
Quarter |
Interval |
1 |
Base Period Type |
Year |
- Click the Forecasts Series Dates tab.
- In the Forecast Series Dates list, click the menu button, and then click New Record.
Forecast Date |
The date when you want to begin running forecasts. This may be today's date. |
Description |
A description, such as Q1 Partner X, Partner Y, and Partner Z Forecast. |
Start Date |
The start date for the forecast period, such as 1/1/05. |
End Date |
The end date for the forecast period, such as 12/31/05. |
- If you want to create additional forecast dates, you can select the record you just created, click the menu button, and then click Copy Record. By default, the new forecast date is one quarter later, and the rest of the fields are the same as in the original record. You then edit the record—for example, to change the description so it refers to the new quarter.
- Click the Forecast Series Participants view tab, and in the Forecast Series Participants list, click the menu button, and then click New Record.
The Add Participants dialog box appears.
- In the Add Participants dialog box, use a query to find the brand owner's channel manager, select this record, and click OK. In the Forecast Series form, click Save.
Only the channel manager who was selected will be able to run a forecast based on this forecast series.
Step 2: Creating the forecast
Only the channel manager at the brand owner organization can run the forecasts based on this forecast series. After the forecast series has been set up, the channel manager can run the forecast. To create the forecast
- The channel manager navigates to the Forecasts screen.
- In the Forecast list, click New.
- In the Forecast Series field of the new record, the channel manager selects the forecast series to be used, such as Channel Manager's Annual Forecast of Partners X, Y, and Z.
- In the Forecast Date field, select the forecast date.
