Siebel Partner Relationship Management Administration Guide > Managing Service Requests > Using Solutions and SmartScripts to Help Partners Solve Problems > Making Solutions Available to PartnersService solutions are answers to frequently asked questions (FAQs). You can create solutions that your customers, employees, or partners can use. You can associate a solution with related solutions and resolution documents, so users can navigate among these related documents. A service agent can associate a solution with a service request or a change request to make it available to the user who logged the request. Solution records may be published internally, externally, or both:
You publish solutions internally to make them available to partners, because Siebel PRM treats partner employees as your employees. Use access control to make solutions accessible to a specific partner or partner community. Use the Catalog Administration screen to add the solution to a catalog that is associated with the partner community for which you want to make it visible. Your partners access these solutions through the Solutions view of the Solutions screen in the Siebel PRM Portal. Partners can browse through the solutions or use a keyword search to find the solution they need. The Solutions view shows a flat list of solutions, which is useful for a keyword search. Alternatively, solutions can be added to catalogs and be made available to users through the InfoCenter screen. Navigation of the InfoCenter is more straightforward. For information on creating and administering service solutions, FAQs, and resolution documents, see the section on solutions and service requests in Applications Administration Guide. |
| Siebel Partner Relationship Management Administration Guide |
