Siebel Partner Relationship Management Administration Guide > Managing Service Requests > Using Solutions and SmartScripts to Help Partners Solve Problems > Making Troubleshooting or Instruction SmartScripts Available to PartnersA SmartScript is a set of branching questions and instructions. The answer to each question determines which question or instruction appears next. Siebel SmartScripts are often used by call center agents who perform troubleshooting. The SmartScript tells them what question to ask the customer. Depending on the customer's answer, the SmartScript tells them the next question to ask. The scripted series of questions and answers helps the agent identify and solve the problem. You can also create SmartScripts to help your customers, employees, or partners solve problems. After you have created and tested the SmartScript, you select the Active check box to make it available. For information about creating and administering SmartScripts, see Siebel SmartScript Administration Guide. To make a Troubleshooting or Instruction SmartScript available to partners
| Siebel Partner Relationship Management Administration Guide |
