Table 5.	Fund Administration Fields
    | Name | Enter a name for the fund (up to 50 characters) for your own use. |
    | Type | Choose Fixed, Accrual, or Mixed to indicate how funding is allocated. |
    | Fund ID | A unique identifier that is generated automatically. |
    | Active | Indicates whether the fund is currently active—that is, whether partners can make fund requests against this fund. Generated automatically based on the start date and end date. |
    | Locked | Lets you lock the fund record so no one can update it. |
    | Period | Optionally, use the Pick Period dialog box to choose a predefined period from a picklist defined by the Siebel administrator, such as 2005 or Jan. 2005. If you do this, the Start Date and End Date fields are filled automatically. |
    | Start  | The date when a partner can begin applying for money from this fund.  |
    | End  | The last date when a partner can apply for money from this fund. |
    | Target Amount | The amount of money targeted to be accrued to a fund. For a fixed fund, the amount of money agreed to in a fund. |
    | Description | A text description of the fund for your own use. Enter up to 150 characters. |
    | Total Credits | The total of all deposits into the fund. Read-only field calculated by the system.  |
    | Total Debits | The total of all the approved withdrawals from the fund (actual amounts granted to partners). Read-only field calculated by the system.  |
    | Fund Balance | The balance in the fund, calculated as Total Credits minus Total Debits. Read-only field calculated by the system.  |
    | Fixed Credits | Credits from fixed deposits into the fund.  |
    | Accrual Credits | Credits from accruals to the fund.  |
