Siebel Partner Relationship Management Administration Guide > Using Market Development Funds > Creating and Using MDFs > Setting Up Fund Approval AuthorizationBefore your company can work with any MDFs, you must authorize the appropriate employees to approve fund requests. Optionally, you can also change the Partner Manager field. The partner manager is the initial reviewer of the fund request, so specifying the Partner Manager field for a partner company determines how new fund requests from that company are routed. Authorizing Employees to Approve Fund RequestsTo authorize employees to approve fund requests, you specify the maximum amount of a fund request that each employee may approve. Employees may get fund requests to review that are greater than the amount that they can approve. After reviewing those fund requests, they can route them to other employees in your company for approval. For example, your channel manager for this company may be authorized to approve requests up to $10,000. If a partner submits a request for $5,000 and the channel manager approves it, then the approval process is finished. The request does not need any further approval. However, if a partner submits a request for $50,000, it is still reviewed by the channel manager initially. The channel manager can either deny or route it to his or her manager for approval. Managers continue to have the option to deny the request or route it to their managers, until it reaches a manager who is authorized to approve the amount. To route the request to the next employee in the approval process, select that employee's name in the Processed By field of the Fund Request record. The employee in this field is the only employee who can change the value of the record. When you select an employee's name in the Processed By field, Siebel PRM automatically routes the Fund Request record to that employee, and it appears in that employee's My Funds Request view. To authorize your employees to approve fund requests
| Siebel Partner Relationship Management Administration Guide |
