Siebel Partner Relationship Management Administration Guide > Working with New Partners > Enrolling New Partner CompaniesSiebel PRM lets you share more sensitive information with partners with whom you have a formal business relationship. For example, if you have entered into a partnership with a company that will resell your product, it is important to share information about accounts, opportunities, and activities with that partner. Siebel PRM lets you share this information with the partner's employees in the same way that you would your own employees. To provide access to this data, you give the partner employees login access to the Siebel PRM Portal. To do this, you must follow a series of steps that will set up this partner company in your system. Typically, this process begins when the partner uses the Siebel PRM online registration to apply to be a part of your partner program. There are other ways that a partnership can be initiated, which are discussed in the section Other Ways of Adding Partner Records. The process of adding partners depends on the following data and structures that are put in place by your system administrator or channel operations manager when Siebel PRM is initially set up:
These steps are described in Setting Up Siebel PRM. |
| Siebel Partner Relationship Management Administration Guide |
