Siebel Partner Relationship Management Administration Guide > Working with New Partners > Enrolling New Partner Companies >
Other Ways of Adding Partner Records
Because it is most common for partners to apply through your Web site, only this method was described earlier in this chapter. However, you can add a partner record in three ways:
- Qualify and register a partner company. If a company applied to be a partner through your Siebel PRM Web site, it has entered the information you need for the partner record. To add a partner record, click Qualify and then in the Partner List, click Register.
- Enter a partner company manually. If a company became a partner without applying through your Siebel PRM Web site, you can enter it in the Partners list manually. When you first set up Siebel PRM, you enter records for your existing partners manually.
- Convert a customer account to a partner. If one of your customers also becomes a partner, you can add it to the Partners list by converting its Account record to a Partner record.
The following section describes the other two other methods of adding a partner record, which are less common but also are useful. After adding a new partner in either of these two ways, you must go through the rest of the process of enrolling a new partner, as described previously. The process using the three methods of adding a new partner is shown in Figure 26.
Figure 26. Process for Adding a New Partner
Adding a New Partner Record Manually
If a company did not apply to be a partner at your Web site, add the new partner record manually. You can enter a partner manually in two ways:
- Add a qualified partner manually. If you have already qualified the partner company, you can enter it manually as a Qualified partner.
- Add a prospective partner manually and promote it. If you have not already qualified the partner company, you can enter it manually as a prospective partner. After it is qualified, you can promote it.
Adding a Qualified Partner Manually
If the partner has been qualified, enter the qualified partner record manually. Then, register the partner and enter the partner profile. To add a qualified partner manually
- Navigate to the Site Map > Administration - Partner screen > Qualified Partners view.
- In the Partners list, click the menu button, and then click New Record to add a new record to that list.
- Fill in the blank record and the More Info view about the new partner with the information in the following table.
Name |
Enter the name of the partner company. |
Site |
Enter a description of the physical location of the partner, such as "Headquarters" or "San Francisco." |
Address, and so on |
Enter the partner company's street address, city, state, ZIP code, and country. |
Main Phone # |
Enter the partner company's main phone number. |
Main Fax # |
Enter the partner company's main fax number. |
Email |
Enter the partner company's main email address. |
URL |
Enter the address of the partner's Web site. |
Currency |
Enter the currency the partner uses. |
Partner Type |
Optionally, click the select button and use the dialog box to choose the type of partner you are adding—for example, aggregator, reseller, or service provider. |
Partner Tier |
Enter the partner tier. Companies might use tiers such as gold, silver, and bronze, or strategic, premier, and alliance. |
Industries |
Optionally, click the select button, and in the dialog box, choose the industries to which this partner sells. |
Territories |
Optionally, click the select button, and in the dialog box, choose the territories to which this partner sells. |
Ranking |
Optionally, enter information about how this partner is ranked against other partners in your partner program, which can help you keep track of your top performing partners. |
Stage |
Use the picklist to choose the stage of the partner's application. Options are Active, Application Pending, Candidate, and Contract Pending. |
Organization |
Use this field to enter the partner's organization, as described in the next section. |
Sales Team |
Select the sales team for the partner company. These are your employees who will see this partner company's record in the My Partners view. |
Price List |
Select one or more price lists that this partner company will use. |
Alias |
Optionally, enter aliases for this partner company, names that the partner company might use in addition to its company name. |
Currency |
Select one or more currencies that this partner company uses. |
Account Type |
Select Partner as the account type. |
Status |
Select the account status: Active, Contract Pending, Marked for Deletion, or Inactive. |
Parent Account |
Optionally, enter the parent company of the partner company. |
Parent Account Site |
Optionally, enter the site of parent company. |
- Click Register, and complete the process of adding the partner company, as described earlier in this chapter in Enrolling New Partner Companies.
Adding a Prospective Partner Manually
If the partner has not yet been qualified, manually enter both the Prospective Partner record and partner profile. At some later time after the partner has been approved, click Qualify to move it to the Approved Partner list, and then complete the registration. Before you add Prospective Partner records manually, you must make sure that the partner managers at your company who add Prospective Partner records have the value Self-Registered Partner Agent in their New Responsibility field. When these managers create new users, the new users will inherit the responsibility in their New Responsibility field. When the prospective partners inherit the responsibility Self-Registered Partner Agent, the partners will be able to log into the Siebel PRM Portal as self-registered users in the interim, until they are qualified. To enter the partner manager's new responsibility
- Navigate to the Site Map > Administration - User screen.
- Use a query to find the employee whose new responsibility you want to enter.
- In the More Info view, click the More/Less button to expand the More Info form.
- In the New Responsibility field, choose Self-Registered Partner Agent.
To add a prospective partner manually
- Navigate to the Site Map > Administration - Partner screen > Prospective Partners view.
- In the Prospective Partners list, click the menu button, and then click New Record to add a new record to that list.
- Fill in the blank record and the More Info view with the information about the new partner.
- Click the Profile view tab and enter the partner profile.
- At some later time after the partner has been qualified, click Qualified to move it to the Qualified list and complete the registration process as described earlier in this chapter in Enrolling New Partner Companies.
Converting a Customer Account to a Partner
You may find that one of your customers wants to become a partner. You can convert the customer's Account record to a Partner record. To convert a customer account to a partner
- Navigate to the Accounts screen.
- In the Accounts list, select the customer account that you want to convert to a partner.
- In the More Info view, select Partner from the Account Type drop-down list.
- Click the Partner check box to select it.
The account is converted to a partner and will appear in the Partners screen, Approved Partners view, as well as in the Accounts screen.
- Navigate to the Site Map - Administration - Partner screen > Approved Partners link.
- Click the Register button to complete the process of adding the partner company, as described in Enrolling New Partner Companies.
