Siebel Partner Relationship Management Administration Guide > Working with New Partners > Enrolling New Partner Companies > Adding User Assignments at the Partner CompanyAs the next step in adding a new partner company, use the User Assignments view to add partner employees as Siebel PRM users. You can also use this screen to update positions, responsibilities, and logins for existing users. NOTE: Partner users must be added as employees to be able to log into the Siebel PRM Portal. The Employee check box must be selected in the User Assignments view tab. This check box is selected by default when a new user is added. Siebel PRM lets you add two types of partner employees:
Delegated administrators can also give employees at their company the responsibility of delegated administrators. Therefore, you can add the person who submitted the application for a partner company as a delegated administrator, and then that delegated administrator can add other employees at the partner company as delegated administrators, who will actually enter the users. After the delegated administrator has added partner employees, you can see them using the Siebel PRM Manager. For more information on adding users and delegated administrators, see Setting Up Siebel PRM. NOTE: If you are using delegated administration, you must make at least one partner employee a delegated administrator. In the User Assignments view, edit the user's record and enter a position and responsibility for the user. To display partner employees who are Siebel PRM users
| Siebel Partner Relationship Management Administration Guide |
