Siebel Partner Relationship Management Administration Guide > Working with New Partners > Enrolling New Partner Companies > Contacting the New Delegated AdministratorContact the delegated administrator at the new partner company to provide more details about next steps. You should tell the delegated administrator to use the Siebel PRM Portal to add new users, including new delegated administrators, and to add user assignments for the employees at the company who will be using the Siebel PRM Portal. You can contact the new delegated administrator personally, or you can set up Siebel Business Process Designer to send the administrator email automatically when the company is added as a partner. The sample data included with Siebel PRM includes a sample of this email and a sample of a workflow that sends it automatically after the new partner company is added. You can use this as the basis of your email and workflow. The name of the workflow is Send Prospect Partner Application Status eMail (Siebel PRM). For more information about Siebel Business Process Designer, see Siebel Business Process Designer Administration Guide. |
| Siebel Partner Relationship Management Administration Guide |
