Siebel Partner Relationship Management Administration Guide > Working with New Partners > Applying for User IDs > Partner Company IdentifierThe final step in enrolling a new partner company is to set up a partner company identifier. A company identifier should be a unique, alphanumeric code such as the Row #of the partner record. When a user clicks the Register for a User Id (for employees of existing partner companies only) link on the Siebel PRM Portal, the user is immediately prompted for the company identifier. The user cannot proceed without entering the company identifier. The user's application appears in the Partner User Applications screen in Siebel PRM Manager. On that screen, the brand owner can view that application and click the Qualify button, which adds the partner to the User Assignments list view on the Administration - Partner screen > Registered Partners view. Use the following procedure to set up a company identifier. To set up a company identifier (brand owner)
On the PRM Portal, a registered user for that partner can find the company identifier and share it with other users who want to apply from that company. Use the following procedure to find a company identifier. To find the company identifier (partner)
After the application has been submitted, the brand owner can qualify it in the Partner User Application view. Use the following procedure to qualify a user. To qualify a user's application (brand owner)
| Siebel Partner Relationship Management Administration Guide |
