Table 4. Server Parameters for Configuring Siebel Configurator Cache Behavior
eProdCfgCacheFS |
Product Configurator - FS location |
String |
Specifies the location of the Configurator File System. If no value is specified for eProdCfgCacheFS, Configurator looks in the Siebel File System. For more information about the Configurator File System, see Specifying the Siebel Configurator File System Location. |
eProdCfgAttrSnapshotFlg |
Product Configurator - Collect and Use the snapshots of the ISS_ATTR_DEF Ob |
Boolean |
TRUE |
Set to TRUE to enable caching for attribute definitions. This caches attribute definitions in memory. It is strongly recommended that you do not change this parameter. |
eProdCfgNumOfCachedAttrs |
Product Configurator - Number of Attribute Definitions Cached in Memory |
Integer |
100 |
Sets the number of attribute definitions kept in memory at any given time during configuration. |
eProdCfgClassSnapshotFlg |
Product Configurator - Collect and Use the snapshots of ISS_CLASS_DEF Ob |
Boolean |
TRUE |
Set to TRUE to enable caching for product class definitions. It is strongly recommended that you do not change this parameter. |
eProdCfgNumOfCachedClasses |
Product Configurator - Number of Class Definitions Cached in Memory |
Integer |
100 |
Sets the number of class definitions kept in memory at any given time during configuration. |
eProdCfgProdSnapshotFlg |
Product Configurator - Collect and Use the snapshots of ISS_PROD_DEF Ob |
Boolean |
TRUE |
Set to TRUE to enable caching for product definitions. This caches product definitions in memory. It is strongly recommended that you do not change this parameter. |
eProdCfgNumOfCachedProducts |
Product Configurator - Number of Product Definitions Cached in Memory |
Integer |
1000 |
Sets the number of product definitions kept in memory at any given time during configuration. |
eProdCfgSnapshotFlg |
Product Configurator-Collect and use snapshots of the Cfg objects |
Boolean |
TRUE |
Set to TRUE to turn on Siebel Configurator caching. It is strongly recommended that you do not change this parameter. |
eProdCfgNumbOfCachedCatalogs |
Product Configurator-Number of cached catalogs |
Integer |
10 |
Sets the maximum number of Model Manager catalogs that can be cached in memory. NOTE: This parameter provides the functionality provided by the parameter eProdCfgNumbOfCachedFactories in previous releases.
eProdCfgNumbofCachedWorkers |
Product Configurator-Number of workers cached in memory |
Integer |
50 |
Sets the maximum number of workers that can be cached in memory. This number applies to all Model Manager catalogs. |
eProdCfgCacheEngineObjects |
Product Configurator - Cache Engine Objects |
Boolean |
TRUE |
Set to TRUE to enable content cache and pre-caching. |
ServerSessionLoopSleepTime |
Integer |
300 |
Specify an interval time (in seconds) to refresh cached products that are mapped to a Configurator server cache or component cache using the explicit product mapping setting. NOTE: eProdCfgCacheEngineObjects must be set to TRUE.
