Pricing Administration Guide > Creating Product Promotions > Process of Creating Product Promotions >
Setting Up Image Files for Product Promotions
When you create a product promotion, you can associate an image file with it. This image will be displayed next to the promotion in catalogs. If you want to show the image in catalogs, you must create the image and import it into the Siebel application in the Administration - Document screen. This makes it available to associate with the product promotion record. This task is a step in Process of Creating Product Promotions. To set up image files for product promotions
- Create the images in either JPG or GIF format.
- Navigate to the Administration - Document screen > Literature view.
- In the Literature list, click New File.
- In the Choose File dialog box, select the image file.
