Product Administration Guide > Basic Product Administration > About Managing Product Records >
Deleting Product Records
You cannot delete a product record. If you no longer want to use the product, you can deactivate all versions rather than deleting the product. If you have a large number of inactive versions for a given product, you can delete the versions using the CleanupSingleObject method of the ISS Authoring Import Export Service. For more information, see Siebel Order Management Guide. To deactivate a product
- Navigate to the Administration - Product screen, and then the Products view.
- In the Products list, select and lock the desired product.
- In the Versions view, deselect the Active checkbox for the Work Space version.
Release the Work Space version.
