Product Administration Guide > Siebel Configurator API Reference > APIs to Interact with Conflicts and Messages >
GetExplanations Method
This method retrieves configuration explanations for an item. Input Arguments
- ObjId. The unique identifier of the complex object root (for example, Quote ID).
- RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- Path. The path of the item.
Output Arguments
The property set returned will have child property sets, each with the property Value as the explanation, as follows: <Output>
<Expl Value="Explanation"/>
</Output>
