Product Administration Guide > Releasing Products and Other Versioned Objects >
Deleting Product Versions
If you no longer want to use a product version, you can release a new version to replace the version that you do not want to use. See Replacing Earlier Product Versions. If you have a large number of inactive versions for a given product, you can delete the versions using the CleanupSingleObject method of the ISS Authoring Import Export Service. For more information, see Siebel Order Management Guide.
