Product Administration Guide > Releasing Products and Other Versioned Objects >
Reverting to Earlier Versions of Products
If you release a customizable product and then make changes to its current work space, you can discard all the changes and revert to a version of the product that you released earlier. When you revert, the entire contents of the current work space is discarded. This includes the product's structure, attributes user interface, rules, links, resources, and scripts. You choose an earlier version, and an instance of it is then loaded into the current work space. To revert to an earlier version
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select the desired customizable product.
- In the Versions list, select the version you want to revert to.
- In the Versions list, click Revert to Released.
- Save the current work space.
