Product Administration Guide > Configuration Constraints > About Managing Configuration Constraints >
Deleting Configuration Constraints
Deleting a constraint removes it from the customizable product. The template on which the constraint was based is not removed and remains available. To delete a constraint
- Navigate to the Administration - Product screen.
- Select and lock the desired customizable product or product class.
- Navigate to the Constraints view.
- In the Constraints List, select the constraint you want to delete.
- From the Constraints List menu, select Delete Record, and click OK when asked if you want to delete the record.
- From the Constraints List menu, select Validate.
This starts a configuration session. Verify that the customizable product constraints function correctly.
