Product Administration Guide > Configuration Constraints > Creating a Siebel Configurator Constraint Summary ReportYou can obtain a report that lists all the configuration constraints in a customizable product or product class. The report shows the following information: The Constraint Summary displays in the Siebel Report Viewer. You can print the report or create an email attachment. This report must be enabled on the report server before performing the following procedure. TIP: The on-screen display of the report typically lists more products on each page than the Products list. Use the report to scan quickly through the product table. To create a constraint summary report
| Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
